Discussion topic: Puck issues
This message was authored by: Gerryggggg
Puck issues
I have two sky pucks I have the sky  whole home package too.
so the pucks should mirror each other they definitely do not. I have one puck in my lounge and one in my bedroom so I've got no idea how to sort this. Any help would be appreciated thanks
This message was authored by: Jporch316
Re: Puck issues
Hi @Gerryggggg
the only parts of the UI that are shared across the pucks are the playlists (and profiles) and the continue watching rail. These will sync across the pucks. If that's not happening pull the plug on the pucks for a few minutes
you will have to log into the streaming apps independently on each puck
Avatar for Gerryggggg
Re: Puck issues
That's the issue the pucks don't give an continue watching option. We have to go to the beginning of a program we are watching. The playlist are the same so I am confused as to why they don't do it . If I unplug the pucks will the playlist still be there when I replug them? Thanks
This message was authored by: Dazzasky
Re: Puck issues
I have started to notice this, if you start on one puck and go to continue on another, it doesn't sync over where you left off and have to restart the puck to be able to continue on the puck.
Re: Puck issues
@Gerryggggg
Yes they will ..... also if you receive a replacement device and sign in to them it will restore your playlist. All the data id stored on your account (not the devices )
Re: Puck issues
So is the playlist data stored on the cloud.  ?
This message was authored by: Hunter2660
Re: Puck issues
There isn't anything stored on the puck, it's all on Sky's servers.
Re: Puck issues
Yes it is
Re: Puck issues
