Discussion topic: Puck box is on but program won’t load .
This message was authored by: SH731
Message posted on 19 Jul 2026 10:10 PM
Puck box on but when when I try to pick a channel it says program can't load
Find out more
Message posted on 19 Jul 2026 10:18 PM
Re: Puck box is on but program won’t load .
Hi @SH731 and welcome to the forum.
Try restarting the Glass by going into Settings > System Management > Resets & Updates > Restart device. It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don’t be concerned when this happens.
This procedure usually resolves this sort of software glitch.
