Discussion topic: Programme Loading & Technical Fault
This message was authored by: Danny297
Having an issue with my Sky Stream tonight which is as follows:
- Turn the puck on
- Choose any channel from the menu
- Channel comes on and displays the error message at the top of the screen "Please wait for your programme to load". This message remains despite the channel working fine
- After a couple of minutes I get an error message saying there's a technical fault with the channel and to try again later. Again this is despite the channel and picture being fine
- I'm then kicked to the main Sky Stream menu
This happens on every channel. I don't hop from channel to channel so I know it's not an issue with the WiFi not being able to keep up. I also have the 500mb full fibre package so can't imagine speed is an issue either - the puck is also yards from my router completely unblocked.
I'd just off the phone with Sky who are sending a new puck out. They say everything seems fine from a diagnostics standpoint on their end and can only put it down to an issue with the puck itself.
In all honesty I have no faith a new puck will work so wondering if anyone else has had this issue and managed to resolve it somehow?
This message was authored by: Stephen+Mourton
Re: Programme Loading & Technical Fault
@Danny297   You seem to be aware of some of the issues that may have caused it.  Can we presume you have disconnected the power from your puck for a minute or so and then turned it back on again?
Avatar for Danny297
@Stephen+Mourton yes that was one of the steps Sky spoke through with me on the phone.
I've had a host of issues with Stream since it was first installed around a year ago (buffering, pixelated image, delay between image and audio, slow menus) however nothing to the extent of this. I don't use it on a regular basis so it's not warranted my time or energy however tonight it was unwatchable. Not sure how others find the service however it's been a real step down from Sky Q for me.
It did stabilise as the night went on however the best of the golf was done by then so it was no use.
