9
This discussion topic has been answered Discussion topic: Problems activating Paramount+ and Disney+
This message was authored by: Liz441
I'm new to Sky. I was sent instructions to activate Paramount+ and Disney+ which are included in my package. However, when I try to open them I get the following message: We'll be back soon. Something went wrong but we're working on it. MYSKY1018.
Any ideas?
This message was authored by: lettice Answer
Re: Problems activating Paramount+ and Disney+
@Liz441
This has been quite a common issue for sometime, for some customers.
Some have found trying the activation process a few times, eventually gets it working.
If not, you will need to call Sky.
This message was authored by: Freddieboy69
Hi @Liz441  welcome to the forum,
I would say as a first thing to try would be to power down the puck by switching off at the mains and unplugging it for about a minute, then plug back in and switch on, then after rebooting try opening the Apps again,
If that doesn't work, from the home screen scroll down to settings, then select 'System Management' then 'Resets and Updates'  then scroll to Refresh Apps' this won't seem to do anything straight away, but will work in the back ground.
Hopefully that help,
Freddie
Avatar for Liz441
Hi Freddieboy69
Thanks for responding. Just tried what you suggested but it didn't  work.
Do Sky have 'techies' you can contact for help?
I couldn't find anything on line.
Hi @Liz441  I'm not sure what else to suggest, maybe someone with a bit more knowledge can help, or escalate it to one of the sky team, possibly @Jporch316 may be able to assist in this?
Regards
Freddie
This message was authored by: Jporch316
Hi @Liz441
the community escalation is currently offline temporarily. I would suggest giving sky a call to troubleshoot the issue.
@Liz441
Avatar for Liz441
How do I contact them? I can't find a number anywhere on the web.
Hi @Liz441
To contact Sky You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number.
Hope that help,
Freddie
Avatar for Liz441
Thanks. I'll phone them tomorrow.
Hi @Freddieboy69  It used to be a simple matter to get the 0333 customer services number via the link you have provided but Sky in their  "wisdom" have not redirected customers to a highly frustrating set of help flows.  It is only when you get to the end of the problem (which is no mean feat in itself) that you will hopefully find a box saying "No, I still need help".  You then need to follow that thread to "I prefer to get in touch"  and when you finally get to an option to "Call us" you need to click that button to reveal the 0333 phone number.
What a rigmarole.
cc @Liz441 as above
