Discussion topic: Pixilating Sky Stream
This message was authored by: Whitstable
Pixilating across all streams. Tried all usual fixes connection speed minimum 45/50. From reading other threads Sky is failing to resolve. Haven't got the will to spend an hour on the phone. Any ideas from Sky's experts?
Moderator note: Changed title to reflect topic more.
Re: Pixilating Sky Stream not fixed by QR270.000.10.09
@Whitstable  You've posted in the Sky stream forum but the release number is for Sky Q, what system do you actually have?
This message was authored by: Dazzasky
Do you have Sky Stream @Whitstable  I'm not sure you do with that software version.
Avatar for Whitstable
I know this mythical code refers to Sky Q. The point was this was the supposed solution to pixilating on Sky Q but Sky Stream remains faulty.
@Whitstable  They are 2 completly different systems entirely,  it's irrelevent what happns on Sky Q.
So do you have Sky Stream ? If you do then the Sky Q software version you have posted has nothing to do with Sky Stream. All you are doing is confusing the situation which results in you getting no help at all @Whitstable
@Whitstable  Your new thread has been removed as your posting  the same info, please don't create duplicate threads.
This one will be retitled by the Community Managers on Monday
And take number out as it was simply sarcasm and gets the "experts" over excited.
