Discussion topic: Picture keeps freezing and akipping
This message was authored by: Pucca
Picture is freezing and skipping. Happening on all channels. Sounds are lagging as well. Have tried resetting the box.. no luck. Dine broadband and WiFi tests which say all is ok. It's constantly happing 4/5 times an hour all day. Any suggestions please?
This message was authored by: Paul466
Re: Picture keeps freezing and akipping
We Are having the same problem. I've reset everything but to no joy. Sky say there's nothing wrong. I'm really disappointed with Sky's streaming service. Very very poor. Sky don't seem to care
This message was authored by: Addie15
Hi there, @Pucca. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Hi @PuccaOne of the main reasons for freezing is the quality and speed of the WiFi signal being received at the TV/puck and not that being received at the router.  This can be checked with the Netflix App (Get help > Check network).  The minimum speeds recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
The important thing with Wi-Fi is to have a stable signal as both Glass and Stream are susceptible to problems if there is any signal fluctuation or interference.  For this reason an Ethernet connection is usually better than WiFi as it maintains better stability. If you try an Ethernet connection don’t forget to turn off WiFi in Settings / Network / Advance settings.
If this is not practical (as in my own home) then you could consider Powerline Adapters which are about £35 on Amazon.  Don’t waste money on a Gb model as Glass and Stream Ethernet ports only support 100mbps.
