712
This discussion topic is read only This discussion topic has been answered Discussion topic: Picture Intermittently Pixelating - Many Sky Branded Channels
Locked
This message was authored by: MontSky22
Re: Picture Intermittently Pixelating - Many Channels
Hi Chloe
With so many people suffering this and being mentioned daily how can you mark this issue as closed?
ill try again
@Chloe-W22 with so many people continuing to have this issue, how it can be marked as answered?
There clearly isnt a suitable answer?
THanks
montsky
Avatar for squareeyeschris
Level 5 icon
This message was authored by: squareeyeschris
Netflix having their own problems live streaming it seems.
@Bluegiraffe @I guess that helps you as Sky are telling me to talk to mine and offering limited help as they can't see the whole chain  😒
Level 5 icon
@MontSky22
No help at all really. Sky is my ISP. They checked my whole chain, said it was all working fine, then sent me a replacement puck, which of course didn't help at all.
Just had my replacement puck - same story
Do you find if you reboot its ok for a few days then problem returns?
I think it maybe a caching issue.
What I find starnge is, i had minimal issues until the big outtage in September, since then nothing but problems 😞
Level 5 icon
@MontSky22
A while since I did a reset so I don't remember. I don't think resetting did anything. Odd you mention caching as I've been thinking along those lines. Insufficient caching in the pucks? Why it should start so suddenly I've no idea, unless something farther up the transmission chain has changed.
I've given up with Sky now so back to Freeview and apps on the tv. Also going to give EE a go for a couple of weeks during the cooling off period.
This message was authored by: KevNewMedia Answer
Posted by a Sky employee
Hi Everyone
Thank you so much for your continued patience and persistence whilst we worked through, what turned out to be a very difficult problem to get to the root of.  We're grateful for the feedback and examples that the Community have provided us with.
You may have already noticed that we have applied a fix for the broadcast of all Sky branded channels. Thank you for your understanding and assistance in helping us to get to this stage of the investigation.
We continue to investigate a problem with ITV's channels, and I'll be moving the recent posts about this issue to a new thread. As soon as we have any updates for this issue, we'll let everyone know on that thread.
If you find that you have a pixelation problem on channels not mentioned above, we'd suggest creating a new thread, so that the Community can provide further technical assistance.
Thank you again, everyone!
Kev
Community Manager
Locked
Answered - Go to Answer
