Discussion topic: Not loading any channels says technical fault
Message posted on 01 Aug 2024 06:06 PM
Done and reset, powered it on and off and still can't load any channels.
Just get. Black screen.
Your My Sky app says nothing wrong when there is?
Message posted on 01 Aug 2024 06:09 PM
Re: Not loading any channels says technical fault
@Hemmo24 If you're referring to Sky Stream puck I would suggest wifi is the most likely issue, have you tried ethernet from the stream ouck to your router?
Message posted on 01 Aug 2024 06:14 PM
Internet is fine, iPlayer, netflix and discovery+ apps work fine via the puck.
Just got no live channels to watch normal TV.
Missing The Simpson
Message posted on 01 Aug 2024 06:17 PM
@Hemmo24 If you have netflix on the puck open it and go to get hlp, run the speed test, although iPlayer netflix etc can run on much lower speeds your TV channels need at least 25mbps for HD & 30mbps for UHD
What does the netflix speedtest show?
Message posted on 01 Aug 2024 09:17 PM
@Hemmo24 wrote:Internet is fine, iPlayer, netflix and discovery+ apps work fine via the puck.
Missing The Simpson
Live channels typically seem to require a slightly stronger Wifi signal and more bandwidth to work compared with the apps, so as suggested by @GD1 your Wifi signal could still be the problem.
Message posted on 01 Aug 2024 11:21 PM
It's sky WiFi running at 109mbps on speed test.
Message posted on 02 Aug 2024 08:25 AM
What is the speed on the Netflix Network check on the Puck?
Message posted on 02 Aug 2024 08:30 AM
@Hemmo24 wrote:It's sky WiFi running at 109mbps on speed test.
Also worth noting that internet speed is only part of it, the strength and stability of the WiFi signal is key for the sky streaming platform as it requires a strong and stable connection to work as intended.
Message posted on 02 Aug 2024 08:35 AM - last edited: 02 Aug 2024 08:36 AM
You can get an idea of whether that is an issue by running a high bit rate UHD demo on YouTube in nerd stats mode for 10 mins on the Puck😉
