Discussion topic: Netflix will not open on sky puck
Message posted on 09 Oct 2025 04:52 PM
I have to re boot the puck every day via settings in order to get Netflix to load.
Message posted on 10 Oct 2025 11:25 AM
Re: Netflix will not open on sky puck
@Ian+McK Is it just Netflix and all the other apps work ok?
Have you tried an App refresh? If not go to Settings then System settings and choose App refresh. See if that sorts it.
Message posted on 10 Oct 2025 11:47 AM
First, try an apps refresh
- Press Home on your Sky remote, then select Settings
- Press System management then Resets and updates and finally Refresh apps.
- You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
You mention resetting, assume that is a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
If after that app refresh '24 hour' period, you are still having an issue.
Launch Netflix, on the left menu options choose 'Get help' and 'Reload Netflix'.
This may log you out of Netflix, so you will need to login to your Netflix account again.
Message posted on 17 Oct 2025 07:55 AM
Thnaks, I have been doing the fist part of the suggestions and am still having problems after 48 hours, I will do the Netflix dorect refresh next..
Message posted on 29 Dec 2025 11:37 AM
I'm having the same problems as OP. I tried all this but still unresolved.
