Discussion topic: Need help with removing HDMC.message on my tv when using my sky stream puck.
Message posted on 13 Feb 2024 06:27 PM
Message posted on 13 Feb 2024 08:37 PM - last edited: 13 Feb 2024 08:38 PM
Re: Need help with removing HDMC.message on my tv when using my sky stream puck.
Probably HDCP (High-bandwidth Digital Content Protection) rather than the Harley Davidson Motor Company.
What make and model of television set is it?
Are you using the HDMI cable provided by Sky?
Message posted on 13 Feb 2024 09:25 PM
If you have an older TV, it's probably not compatible with HDMI 2.0. There's a certain amount of backwards compatibility but I believe this only kicks in from HDMI 1.4 and above
