Discussion topic: My stream doesn’t work on my lounge tv
Message posted on 19 Mar 2024 06:10 PM
Hi I have just moved I have sky glass and sky stream my wire out the broadband into the stream box is not long enough to fit do you know what I can do because I havnt managed to get the sky working in my living room or child bedroom but the sky glass tv is working with the broadband
Message posted on 19 Mar 2024 08:01 PM
Re: My stream doesn’t work on my lounge tv
Hi @Kate12345-
What is your internet speed and WiFi signal like? You can run the pucks off wireless if you have good enough signal.
To connect to new router you will need to reset your connection: https://www.sky.com/help/articles/sky-glass-no-wifi-connection-osm
Alternatively if you want to use ethernet, you can buy some network home plugs this allows you to use the wiring in your home to transmit data. Something like https://amzn.eu/d/b3KhDdH.
MikeAlanR
