Discussion topic: My remote keeps changing channels on my puck
Message posted on 02 Feb 2024 11:28 AM
Sky stream puck seems to change channels randomly and fast forward programmes etc
Message posted on 02 Feb 2024 01:01 PM
Re: My remote keeps changing channels on my puck
To help you try to get your remote working the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
