Discussion topic: Intermittent
This message was authored by: PER1
Intermittent
I am using sky stream with a puck since November and service is intermittent.  Sound goes then grey screen. Sometimes a reboot works but it is not always on one channel but multiple channels. Watching the Olympics is easy using my smart tv but when using Sky it really is frustrating.  I have BT full fibre and speeds are more than required. Any advice please?
Re: Intermittent
What does "speeds are more than required" mean? You need to measure the actual speed your puck is receiving, not the speed your ISP says you are receiving.
Run a network check from the get help menu on the Netflix app. This will give you an idea of the speed being received. It needs to be a constant 25Mbps absolute minimum with no interference for the puck to function reliably.
Stream pucks are quite susceptible to interference from other devices and don't like speed fluctutations.
