Discussion topic: ITVX app will not load beyond splash screen
Message posted on 22 Jun 2025 06:36 AM
I know there have been posts on here before about similar issues, but there doesn't appear to be any solution.
Current situ: loading the ITVX app fails to move beyond initial splash with logo.
I have reset apps, soft and hard resets of the puck and no joy. The code to reset the ITV app is not accepted on the splash - I gather you need to enter on the initial menu, which I never get to. Regularly use BBC, Netflix, Prime, Apple, YouTube apps without issue. ITVX hasn't worked for months.
I've had Stream for a year, and app worked initially. ITVX was always a little unreliable and occasionally failed to stream, and then occasionally left the whole Stream in a broken state needing a power pull.
Any ideas?
Message posted on 23 Jun 2025 08:14 AM
Re: ITVX app will not load beyond splash screen
