Discussion topic: How do i get theremite to work to set up sky streaming
This message was authored by: Joanne120
How do i get the remote to work to set up sky streaming
Re: How do i get theremite to work to set up sky streaming
Have you pulled out the paper strip which insulates the battery? If it didn't pull out cleanly, you might need to open the remote and remove it manually.
