Discussion topic: Home move and sky box changes
This message was authored by: Kenny+Rankin
I will be moving to a new build house in a couple of months. I have decided not to erect a dish and instead switch from Sky Q to Sky Stream. Since I will no longer be impacted with Sky Max WiFi incompatibility with Q, I will order the new router too.
I will need to strange a Hone Move nearer the time and am debating whether I should swap from Sky Q to Stream and WiFi Max now in my current house then arrange a home move of my broadband when new build is ready, or do I wait then do everything at once.
I have full gigafast FTTB at both addresses  and am out of contract on Sky Q.
What would you do, any pros or cons with either option ?
—————————————————————————————————-Sky Stream, Sky Gigafast Broadband with SR203 Hub
Re: Home move and sky box changes
If you are out of your minimum term on Q now, there is a good chance you will be able to reduce your Sky TV bill if you switch over to Stream now. It may be worth at least giving Sky a call over the weekend and ask what price they would give you to move to Stream. At least that way you could compare that to your current Sky TV subscription cost and then figure out what saving there may be.
