Discussion topic: Going away
This message was authored by: Chloe142
Going away
I am going away in the uk, i have a subscription to Sky can I take my puck with me to use
Re: Going away
No. That would break the terms and conditions of your contract.
Avatar for Chloe142
Level 4 icon
Re: Going away
Another Sky con then
Re: Going away
@Chloe142
As detailed below taken from the Sky Stream FAQ, which also has further linked T&Cs and articles to read;
You can only watch your Streaming TV subscription on your Sky Stream puck from your registered home address – the address on your account. We cover this in your Streaming TV subscription contract (see Sky Terms and Conditions).
You can still watch your Sky subscription while you’re out and about by downloading the Sky Go app on your laptop, tablet, or mobile phone. It’s just if you watch on your Sky Stream puck outside your home that we might charge you extra.
To find out more, see our Use of Streaming TV subscription outside your home address article.
https://www.sky.com/help/sky-tv/sky-tv-stream/sky-stream-faqs/articles/sky-stream-faqs
Re: Going away
It's not really a con. It's on the contract you signed to take out the subscription.
You can use Sky Go on mobile devices if you want to watch Sky content.
Re: Going away
Hardly. It's what you agreed to.
Re: Going away
Not really: Stream was never advertised as being a portable media device to use anywhere (although there's no technical  reason why it couldn't be as long as it gets sufficient bandwidth)
Sky-branded television hardware has always been contractually tied to a single residential address: when NowTV had dedicated hardware it was fully relocatable (as it is now in app format)
This message was authored by: peter-marlow+1966
Re: Going away
If you use your puck anywhere other than the address you registered it at sky will charge you an extra £26 on your bill, it is con a con, you agreed to the terms when you signed up
P c marlow
This message was authored by: Tommy2
Re: Going away
@TimmyBGood  Im aware they can pick up if you use at a different address through your IP address but id be interested to know how long it would take for this to happen.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
