Discussion topic: Extended hdmi for sky stream
This message was authored by Kimberley1991 This message was authored by: Kimberley1991
I just recently got sky stream and we have a false wall we would like to hide the cables in however the hdmi given is not long enough, will any standard extended hdmi cable work, I seen they do sky ones but alot of the reviews were people saying this worked with sky q so I wasn't sure if this would be suitable. Any advice would be appreciated.
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek
Re: Extended hdmi for sky stream
Any high speed HDMI cable can be used, but using one longer than 3 metres can cause issues if you are watching in UHD.
@Kimberley1991
And whatever you get, test it (at UHD resolution) before it goes in the wall.
As @Mister_Dalek indicates, three metres is typically the limit for passive HDMI, but active cable is now much more reasonably priced than it used to be.
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@Kimberley1991  Get a certified 2.1 HDMI cable they may cost a bit more .... BUT they are more likely to meet your requirements😉
Exiled in HH
Kimberley1991
Thanks very much for this advice, I will do exactly that. Thank you!
