19 Feb 2024 07:26 PM
I've already tried swapping the Stream puck and the Apple TV box around, but unfortunately, I still didn't get Dolby Vision. It seems like the issue might not be related to the HDMI ports on the TV. I appreciate the suggestion though
20 Feb 2024 07:28 PM
Got a similar TV to you got the G3
And only had Streaming for four day's
+ a Yamaha up 8K Amp
And a nvidia shield tv [tube thing] plugged in to Amp next to the puck.
I'm with you bruv, Sky Stream does NOT do Dolby Vision, just checked Netflix and that DOES do Dolby Vision.
I love me footy but on UHD games they are only displaed as HLG HDR [gotta tone down the bright, it's searing]
20 Feb 2024 10:36 PM
Must be some kind of incompatibility with certain LG models then because Sky Stream does output Dolby Vision from its Netflix, Disney+, Apple TV+ & Prime Video apps on my Panasonic OLED.
Could it be that your LG's will only receive Dolby Vision at certain frame rates? One of the downsides of the Stream pucks is their inability to output native frame rates from third party apps. They can only output at 50Hz or 60Hz (with judder reduction turned on.) Some TVs can only accept Dolby Vision at 24P, 25P or 30P.
21 Feb 2024 07:05 AM
@Padam_Padam I have an LG G2 and can confirm that my Stream Puck does indeed output Dolby Vision on the Netflix, Prime Video, Apple TV+ apps without issues. I trust those with LG Oleds have set the HDMI input to Deep Colour?
21 Feb 2024 12:45 PM
Read my post properly pal.
Thats what I said.
21 Feb 2024 12:53 PM
@wildsid wrote:Read my post properly pal.
Thats what I said.
Sky's own UHD HDR content such as live sports and Sky Cinema, does not stream in Dolby Vision and never has done - it only ever streams with HLG HDR.
This is correct. The Netflix app on the Sky Stream puck does output Dolby Vision.
29 Mar 2024 08:05 AM
Hi been reading up on problems with sky stream and Dolby vision on Disney and Netflix on an UHD HDR LG TV. I would get picture interruption or flickering and then the Dolby vision icon would appear as if it had re-connected to a new picture setting. I phoned sky - went through the usual checks and re-sets and even got a new puck. It was better or at least watchable but still wound do the picture reset thing. After a while it got worse again so I swapped hdmi ports and it was a little less frequent. So I decided to get new quality HDMI cable and it works perfectly now. I was using the sky provided HDMI. I bought Anker ultra high speed model A8743 off Amazon c£14
29 Mar 2024 10:53 AM
Sky have aimed for the majority of customers with the HDMI cable as it only supports HDMI 2.0 but the Puck is HDMI 2.1.
This set up works fine for most people (and saves a few quid for Sky/Comcast) as HDMI 2.0 has a maximum bandwidth of 18Gbps which is perfectly good for UHD, HDR10 & HLG.
However, when you introduce low video compression, Dolby Vision and Dolby Atmos into the mix, you're going to run into bandwidth issues as you're shifting around much more data. This is where you need to spend £10 or so on a HDMI 2.1 cable as this will increase available bandwidth to 48Gbps.
If you have a TV that supports all of these formats, it should also support HDMI 2.1.
29 Mar 2024 01:14 PM
Yeah - sky don't tell u this and I spent ages on the phone with sky and never really got fixed - and they could have just said try a better HDMI lead! It took me a while to find the posts to solve so thought I would add in to the mix 😀
29 Mar 2024 01:25 PM
@SJRed I uncovered all of this while trying to diagnose Audio dropouts on our new TV and Atmos soundbar a couple of years ago... I never knew about the bandwidth limitations of different versions of HDMI before then 🤣
29 Mar 2024 03:58 PM
@SJRed wrote:Yeah - sky don't tell u this and I spent ages on the phone with sky and never really got fixed - and they could have just said try a better HDMI lead! It took me a while to find the posts to solve so thought I would add in to the mix 😀
Sky Stream is a mass-market product. The vast majority of customers and Sky advisors don't have a clue about HDR. Dolby Vision in particular is still very much seen as a niche A/V enthusiast type of format which Sky have no real interest in. If it saves them a few pennies to put a lower spec HDMI cable in the box then that's what they'll do.
29 Mar 2024 04:57 PM
@SJRed I'd be surprised if any of the Sky front line advisors know what the various HDR formats are to be honest as most people really don't care. We are in the mass minority of geeks that do care.
The retention person at my old TV package supplier told me that I'll get every channel in Ultra HD with HDR and Atmos even BBC and ITV because the box supports this and it's all included. I had a right good chuckle at this one . 🤣
