Discussion topic: Disrupted audio
This message was authored by: Marcus59
Message posted on 11 Jun 2024 06:02 PM
Disrupted audio
The audio in programs keeps breaking up and sounding like it's blowing bubbles
Find out more
Message posted on 12 Jun 2024 07:08 AM
Re: Disrupted audio
@Marcus59 it is worth experimenting with thecaudio output tupe in the pucks settings menu as thecdefault Auto maybe causing issues. If you use your TV's speakers the PCM option should wiork as it is plain stereo signal. If it presists post details of the `tV and any sound kit you are using includingbhow they are connected.
