Discussion topic: Continue Watching Issue
Message posted on 19 Dec 2025 12:12 PM
Hi,
I've got a Sky Max show stuck in continue watching.
Start watching it and all is fine and then screen goes blank. Tried fast forwarding and it works for a while before screen going blank again.
It's not in the playlist so can't delete from there. There's no blue bar when I look at it in continue watching so it obviously doesn't think I've watched any of it which is why its probably still there.
Any ideas ? One for @KevNewMedia perhaps as I think it's a bug?
Thanks,
Dave
Message posted on 19 Dec 2025 01:50 PM
Re: Continue Watching Issue
Hi @Anonymous I suspect the programme you have that is stuck is SWAT S8:E22 as I have exactly the same. I have tried all my "tricks" to get rid of it without success. As I have said many many many times the CW rail needs a delete button or at least some method to remove programmes from it.
Unless Sky fix the problem with that specific episode of SWAT there is little to be done other than to just ignore it and it will slowly make it's way to the end of the CW rail and hopefully drop off the end.
Message posted on 19 Dec 2025 02:01 PM
Hi @Fothergill1
Yes it is Swat I have the problem with.
I agree a way of deleting from the continue watching rail is needed.
Just have to wait until it drops off at some point.
Thanks for your help and taking the time to reply.
