Discussion topic: Constantly unreliable sky stream.
This message was authored by: Junkyarddog
Message posted on 28 Feb 2025 07:24 PM
Sky stream has been unfit for purpose, constantly freezing, judge ring, sound out of since, and sconstantly just turning off since I had it.
Message posted on 28 Feb 2025 08:17 PM
Re: Constantly unreliable sky stream.
Hi @Junkyarddog the sound sync is a known bug and hopefully there'll be a fix soon.
Some of what you said sounds like it might be network related so if you don't mind I think it'd be worth looking into that a bit.
- Open the Netflix app on your Sky Stream Puck.
- Go to Get Help in the sidebar.
- Select Check Your Network.
- Note the download speed
Please could you share the speed it shows?
