Discussion topic: Constant buffering and audio loss
This message was authored by: BillyPre
My sky TV box set keeps buffering and losing audio on all apps. I have attempted reset of the box set as well as wifi but still does the same thing
This message was authored by: Stephen+Mourton
Re: Constant buffering and audio loss
@BillyPre   There can be several reasons for this, so read the forum for further suggestions.  However you need a strong internet speed so go to Netflix even if you don't subscribe, they have a speed check in their settings menu.  Also the placement of your puck is important.  If not using an ethernet cable make sure the puck stands alone not touching anything except the shelf it is on with at least 6 inches of space around it.  I hope that helps.
