Discussion topic: Connectivity
This message was authored by: Flat16
Connectivity
No connecting  - TV comes up with a blue screen with SKY flickering on the top left corner. Tried turning off by the main switches several times but still not working. WiFi is working perfectly on other devices.
Re: Connectivity
Sounds like it's most likely the HDMI cable between the puck and the TV. Check that it is firmly connected at both ends or try a different cable and/or a different HDMI port on the TV.
