6
This discussion topic has been answered Discussion topic: Connecting Skystream via ethernet
This message was authored by: chess64hedgepig
I want to try connecting my Skystream puck using Ethernet cable. Will this automatically switch the connection from Wi-Fi to Ethernet? I want to be sure that it doesn't stay with Wi-Fi, despite connecting the cable!
So, how do I disable the wireless option on Skystream?
Thanks,
Pete
This message was authored by: martswain Answer
Re: Connecting Skystream via ethernet
Go into the puck settings and turn off the WiFi, it's as simple as that.
Settings > Network > Advanced settings  and toggle WiFi to off.
Thanks,
Pete
@chess64hedgepig  You will need to physically turn off the WiFi at Settings > Network > advance settings where you will find a WiFi on/off toggle.
When connected via Ethernet be aware that the Stream port only supports up to 100mbps so you are likely to get a speed reading of 85-90mbps.  This is more than adequate and more importantly is probably more stable than WiFi.
This message was authored by: Mick183
Will I be able to recor d then from the sky q  box.
Will I be I be able to record  with the sky q box
@Mick183 if you subscribe to Stream then your Sky Q box will stop working.
You cannot have both.
This message was authored by: Dazzasky
No you can't
