Discussion topic: Connect to wifi
Message posted on 28 Feb 2026 03:27 PM
Connect to wifi
Hi, I have just installed a new router ( not Sky) but my Sky Puck can't connect to it even though I have tried several times with the new password. The router is working as other devices have connected. Any help please, thanks
Message posted on 28 Feb 2026 03:34 PM
Re: Connect to wifi
@Ian408 you've posted in the Sky landline forum. I'll move your post to the Stream forum.
Message posted on 28 Feb 2026 03:37 PM
Re: Connect to wifi
Thank you
Message posted on 28 Feb 2026 03:50 PM - last edited: 28 Feb 2026 03:53 PM
Re: Connect to wifi
Can you work your way through this Sky help article and see if that helps?
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
If after setup 3, your still having issues, come back here for further help.
Message posted on 28 Feb 2026 04:28 PM
Re: Connect to wifi
Hi, thanks for the reply, I have tried all these steps and still can't connect. The puck was working fine this morning until I had to swap routers . I have not touched any cables on the puck or TV so can't be any loose or incorrect connections
