2
This discussion topic has been answered Discussion topic: Can i delete a programme on playlist on sky stream
This message was authored by: Shirley73
Can I delete individual programmes off my playlist on sky stream
This message was authored by: MarkGoldsmith Answer
Re: Can i delete a programme on playlist on sky stream
@Shirley73 Unfortunately you can't. The playlist is based on an entire show rather than individual series or episodes. Its functionality is pretty standard for streaming services and is similar to lists or watchlists you find on other streaming apps.
This message was authored by: Jporch316
@Shirley73
As well as the above .... your playlist will track which episodes you have watched so that when you select the show you want to watch it will automatically suggest the next unviewed episode for you
