Discussion topic: Buzzing sound through TV when Sky Stream is on, any fix?
This message was authored by: AlexLee
Recently bought a new TV and at first Sky Stream was working fine but now there's a slight buzz through the speakers whenever using the Puck, both the TV and my Xbox Series X are working as expected. I did recently add a 2 month trial of UHD / Dolby Atmos, any chance it could be that? It was working fine before I added that but unfortunately I am stuck with it until 5th of October.
I have tried changing the sound settings on the Puck and the TV and while it definitely helps I can still hear it slightly, it only happens when there's no other sound, any ideas? I found another post but nothing there helped me.
I should also mention I tried another HDMI cable ( the one from my Xbox ) and tried another HDMI port but no luck.
This message was authored by: Mister_Dalek
Re: Buzzing sound through TV when Sky Stream is on, any fix?
@AlexLee
I'd ask Sky for a replacement puck. They shouldn't cause interference with your TV.
Avatar for AlexLee
Level 2 icon
Yeah I'm going to give them a call Monday and inquire about a replacement, hopefully it is a puck issue, thank you!
