Discussion topic: Amazon Prime and Netflix not working on Sky Stream.
This message was authored by: NotEnoughTime
Hi fellow Sky Stream users,
I'm starting this thread to raise awareness about Sky Stream's poor connectivity issues with Prime and Netflix. I know I'm not the only one experiencing this, since I started with the service, over a year ago.
Reguarly when I select to watch a program or movie on either of those platforms via the Sky menu, I end up with a blank screen followed by a random error message, sometimes about my HDMI cable. There's nothing wrong with the cable and usually after 3-4 tries, it finally plays the program.
Also I have an Apple TV box connected to the same TV and I can instantly switch to it when I get this issue on Sky, and navigate to the same program on either Prime or Netflix and it plays immediately. To be honest I would dump Sky if it wasn't for some programs.
Ps I have the Sky puck connected via Ethernet to my router and am using a 1GB FTTP internet connection, so no issues with internet connection or speed.
Re: Amazon Prime and Netflix not working on Sky Stream.
FYI - If you prefer the more reliable Apple TV box then all Sky content is available on it via the NOW TV app with the relevant subscription. I switched to this a while ago and haven't missed Sky Stream at all.
Avatar for NotEnoughTime
Cheers, I did have a look at this a while back. It may be time for a revisit.
