2
This discussion topic has been answered Discussion topic: 3rd party broadband router with sky stream
This message was authored by: Frankster999
Hi, my Sky Broadband broadband is slow/unstable so want to switch to  Virgin Broadband. How easy is it going to be to set up my Sky Stream with the new router ( I'm led to believe this is possible).
A step by step guide would be handy if possible as I'm not that technically minded.
This message was authored by: Nigelb1972 Answer
Re: 3rd party broadband router with sky stream
Just head into the Network settings and scan for the new network and it should pick it up and away you go ...
We had a fibre network fault a couple of weeks ago and I set mine up to hotspot from my mobile. It took a couple of minutes 👌🏻
@Frankster999 You shouldn't have any issues setting up Glass with another broadband provider.
You would need to go to Settings > Network > Network Connection and select reset.  This will take thou through the setup where you enter your new network name and password and you should be up and running again.
If you have any issues you can post back here for further advice.
Good luck
