Discussion topic: 2nd puck wont accept pin
This message was authored by: Corinne11
My 2nd puck won't accept pin. It works on main device
This message was authored by: Jones_The_Cat
Re: 2nd puck wont accept pin
Which PIN?
@Corinne11 is this the PIN you need to entered on the initial setup?
Did you change this PIN after using the default PIN when you setup your first puck?
Avatar for Corinne11
Sorry I didn't explain it properly🙈 it's the parental pin that I need to enter if I want to watch certain programmes before 9pm
It is the pin associated with last 4 digits of my phone number linked to sky set up I haven't changed it and it worked no problem on main puck
@Corinne11 if you haven't tried already, your problematic Stream puck, try unplugging it for 10 minutes, then plug it back in and see if it starts recognising the correct PIN.
