Discussion topic: Issue with purchased movie
Message posted on 23 Sep 2024 07:55 PM
I have purchased blink twice on sky store to rent, however 26 minutes in the sound with the movie stops and a whirring nose starts and continues throughout the movie, anyone else had this issue?
Message posted on 24 Sep 2024 08:01 PM
Re: Issue with purchased movie
Same thing happening with me, deleted the file, redownloaded and even skipped ahead to see if it was part of the movie...
Message posted on 24 Sep 2024 08:10 PM - last edited: 24 Sep 2024 08:35 PM
It does sound like a corrupted file @Jh30 @AC90
The fact it's happened to two people in the same way suggests there may be an issue at the Sky end but it's really hard to know without getting in touch with the Sky store team.
It may be worth trying to delete the partial file. Then go to your recordings / manage / deleted setting and delete the rental again out of there.
(if you miss out this step and just redownload, you will bring back the same file you deleted).
Then try to download again (but bear in mind even if it works you will only have 48 hours from when you first pressed play, until the rental window ends)
If that doesn't help, the Skystore contact link is here, but livechat isn't open until 11am Wednesday
Hope that helps
https://www.skystore.com/n/hcus/help/contact-us
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
