Discussion topic: Device issue , error 1100 sky store
This message was authored by: Boo252
Hi,
I can't use sky store. The payment is taken and all I get is an error message saying error 1100.
I have refreshed all apps, powered on/off
Reliaded everything and it's still the same.
Device limit met, but only two devices are in the settings.
I cannot make a device change until February 1st
Sky will charge for a movie but it can't be played. I tried a cheap one to see if it can be played but it won't.
any help appreciated
thanks
Re: Device issue , error 1100 sky store
@Boo252
You might want to get in touch with Sky Store support regarding this, they have a live chat you can use that is available from 11am-7.30pm Monday to Saturday and can be found here:
https://www.skystore.com/help/contact-us
This message was authored by: Kaislee
It's a latency issue between the sky glass & the sky hub.
Each Error Code: 1100 is the SGA is unable to connect, also the servers treat each failed connection as a new device until you've reached device limit, then asks you to remove a device to add the SGA & then tells you you have reached the device limit again. It's a viscous circle.
If possible, can you connect the SGA to the Sky Hub via Ethernet cable, preferably CAT 6. Then you'll need to contact Sky to reset the devices associated with the Sky Store account.
Sky Store Tech Support are aware of the issue & have seen a rise in cases over the past 6 months. Everything is ok on their end, it's a hardware issue that Sky Stream/Broadband need to resolve.
Avatar for Boo252
Hi was in touch with Sky online. They refunded the money paid for the movie but offered no resolution to the fact I can't watch movies.
thanks for your replies
This message was authored by: moviefan2026
I dont think that is the case. 1100 is a consume error but I think it is a red herring in this case.
Not sure what the issue was, but think it might be working now
