Discussion topic: Can not reset my pin number
This message was authored by: Captain+Moron
Can not reset my Sky Store pin number
Receive a reset email but put my new pin in but it says time expired
Re: Can not reset my pin number
@Captain+Moron It is a common practice with many reset emails or codes (not just Sky) that they are only valid for a certain length of time.  As it had already expired when you went to enter it you will need to request another.
