Discussion topic: Audio problems
Message posted on 21 Oct 2021 03:15 AM
Audio problems
Anybody else receiving audio problems of sky store I only had my tv for 2 weeks and I am getting sound on and off
Message posted on 21 Oct 2021 09:11 AM
Re: Audio problems
Hi @Appleby01
Can you go in to more detail
What are you experiencing? When does it happen ? What setup do you have ?
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 22 Oct 2021 05:04 PM
Re: Audio problems
When I play a film in sky store the audio is on and off it happens every 5 seconds but the trailers works perfectly
Message posted on 22 Oct 2021 05:25 PM
Re: Audio problems
hi @Appleby01
I'll try to answer assuming you are referring only to Sky Store.
But can you clarify
is it one movie only or all movies ?
rental or Buy and keep ?
are you on Sky Q or Sky HD ?
what audio output is your Sky box set to ?
are you using TV speakers or external speakers ?
The things I'm thinking about are -maybe audio settings / corrupted download but you would need to provide more details. Very hard to offer suggestions based on what you have provided so far
Sky Q 2TB main box
LG CX6LA from 2020
