This discussion topic is read only Discussion topic: Ps4 connection
This message was authored by: Ants+H
Ps4 connection
Can I connect a PS4 to my soundbox? As it says Bluetooth connection not supported? But it found it initially. Can I use the hdmi from the ps to soundbox to TV and just use optical connection for the sky q?
AH
Locked
This message was authored by: leemcqueen4270
Re: Ps4 connection
You can only connect a ps4 via the optical cable.
Avatar for Ants+H
Level 3 icon
Re: Ps4 connection
There's no optical on this PS4, It's just power and hdmi 🙄 So I thought that I'd put ps4 hdmi to sky soundbox & then soundbox hdmi to TV. Then put sky Q hdmi straight to TV & sky Q optical to soundbox 🤔
AH
Re: Ps4 connection
That should work: your only limitation might be that you find your television cannot pass the better Dolby Digital standards over optical-out to the Soundbox, which is why it is preferable to have it in an HDMI chain.
Avatar for Ants+H
Level 3 icon
Re: Ps4 connection
Okay. The above seemed to work okay, sky worked via optical and ps4 via hdmi to soundbox then hdmi to TV 📺.
Then, when I played another bluray the background sound could be heard, but none of the actor's voices.
If I changed from English to English audio description, then i could hear everything, as well as the audio description.
Help!!! 🤔
AH
This message was authored by: Wormop
Re: Ps4 connection
I've just hooked up my PS4 Slim to my Sky Soundbox and got the same issue - when I play a Blu-ray the central channel (usually voice) is silent. Any ideas please?
Avatar for Ants+H
Level 3 icon
Re: Ps4 connection
Sorry, but I gave up in the end, and kept my ps3 withe my TV and soundbox downstairs. Put the ps4 upstairs🙄🙄
Unless you have optical out on your ps4 you're going to struggle🤷‍♂️
AH
Locked
