Discussion topic: wifi connection
This message was authored by: Gary1958
Message posted on 17 Sep 2024 12:05 PM
wifi connection
My box is pairing up to my BT router but when i enter the password it comes back as the password is wrong but it is correct all other equipment is working fine
Find out more
Message posted on 17 Sep 2024 01:15 PM
Re: wifi connection
Hi @Gary1958
Assuming you are trying to connect to the BT router 2.4Ghz band.
SSID and password is always case sensitive.
If it will not accept it you must have made an error on entry.
