Discussion topic: technical fault with u channels
This message was authored by: Liz140
technical fault with all u channels. Have tried drama, alibi etc
Re: technical fault with u channels
Hi @Liz140
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
The U& channels had some technical changes today which your box may have missed, rebooting the box should fix it.
