Discussion topic: sound problem
Message posted on 16 Jun 2025 09:38 PM
sound problem
I seem to have accidentally changed from SKY to outside speakers. I have to reset my sound every time I switch on. If I do not do this, I have no sound. I hae no conrol over the volume of my sound.
Message posted on 17 Jun 2025 06:34 AM
Re: sound problem
What does "reset my sound" mean? This sounds like aa TV setting.
Message posted on 17 Jun 2025 10:24 AM
Re: sound problem
hi @EVP1
This sounds like a TV menu setting to use an external Sound bar or AV equipment - My Panasonic TV uses the name Home Cinema
Please may I suggest you use your TV's own remote to look at the Sound options and set this back to TV (assuming you are using the TV's own speakers)
