Discussion topic: skyQ box error
Message posted on 28 Apr 2025 12:05 PM
skyQ box error
Sky Q box says no harddriive
who can I talk to and get connected with Sky protect
Message posted on 28 Apr 2025 12:12 PM
Re: skyQ box error
@erik7 As you have Sky Q Sky customer services will be able to deal with any issues as the box is loaned to you, you'll need to try calling later as the lines are down currently.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 28 Apr 2025 05:18 PM
Re: skyQ box error
@erik7 or if you follow the link below it should lead you to orgering a replacement box as hard drive errors are normally terminal
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
