Discussion topic: sky q
This message was authored by: windows+phone+8
sky q
when changing channels the ifo screen in bottom left corner is very faint
Re: sky q
Hi @windows+phone+8
Try rebooting your Q box.
Re: sky q
Best to keep it on the forum @windows+phone+8
As it helps others .
Avatar for windows+phone+8
Re: sky q
tks will give that a go, appreciate your help.
cheers.
