Discussion topic: sky q keeps disconecting from the net
Message posted on 23 Mar 2025 10:32 AM
four times in a row when i turn my tv on and sky q box it has disconected from the net
Message posted on 23 Mar 2025 10:42 AM
Re: sky q keeps disconecting from the net
Hi @steve-brack
Are you reconnecting it as follows:-
