Discussion topic: sky q box keeps turning off
This message was authored by: SKYQDOWNLOAD
How do i stop this? Ive updated box,turned off and on did all the things i should turned off sleep mode but to no avail
Re: sky q box keeps turning off
Hi @SKYQDOWNLOAD
