Discussion topic: sky minibox
This message was authored by: krusty
Message posted on 07 Jun 2025 03:10 PM
sky minibox
when moving a tv and sky minibox to another room do you have to have an ethernet cable?
Message posted on 07 Jun 2025 03:17 PM
Re: sky minibox
@krusty I believe they can connect via WiFi but you get a better, more stable connection using ethernet. The best way to do this is using Powerline adapters. You plug one in by your router, the other by your moved minibox and connect to both adapters using an ethernet cable. A pack of two adapters and buying two ethernet cables can be done reasonably cheaply.
