Discussion topic: sky mini box not connecting
Message posted on 30 Jul 2025 03:33 PM
My main Sky Q box is connected, one of my other Sky mini boxes is connected, however one of the other Sky mini boxes will not connect and I get message M006
I have tried resetting the mini box etc, without success and I'm running out of patience, really!
Message posted on 30 Jul 2025 04:16 PM
Re: sky mini box not connecting
@Inspector Have you tried rebooting your main Q box ie
then
rebooting your mini boxes
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 30 Jul 2025 04:25 PM
Hi @Inspector
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
