Discussion topic: sky had box
This message was authored by: Darren171
sky had box
Having to reset the hard drive weekly as keep losing my recordings and connection to my q box
This message was authored by: Doc5907
Re: sky had box
@Darren171
If you keep having issues and have worked through the below help link it eventually gives the option to request a replacement from Sky which you may need..
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
If you do eventually end up replacing the box make sure you remember to take out the viewing card from old box.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Darren171
Re: sky had box
Great thanks, have requested a replacement .
