Discussion topic: remote numeric keys repeat entry, key not sticking.
This message was authored by: York1915
When pressing any numeric key it often repeats. The key on the remote is not sticking.
Re: remote numeric keys repeat entry, key not sticking.
@York1915
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
(It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare).
