Discussion topic: remote broken
This message was authored by: bitiratehere
remote broken
Downloaded sky+ but cant use it as a remote as there is no feature for it, it says click setting in the corner of the app but this does not exist, is there anyway to change channels without a remotr
Re: remote broken
hi @bitiratehere
the SKY+ app was not for SKY Q
If you have an IOS device the latest version of SKY Go (the current app) has  a virtual remote but if you only have Android or PC this feature is not yet available unfortunately.
I believe there may be some 3rd party apps but I am not usre
Avatar for bitiratehere
Re: remote broken
Thanks, i will have to check, this is a major design fault for Sky
Re: remote broken
@bitiratehere
You can purchase a new remote for Sky Q from most major supermarkets or Argos etc or if you follow this link it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
