Discussion topic: recrding
Message posted on 25 Jan 2026 12:08 PM
recrding
Television working with good picture quality.
When recording programs the picture is breaking down and pixles interferance when playing the recorded program
Message posted on 25 Jan 2026 12:11 PM
Re: recrding
Hi @Reve1944
