Discussion topic: recording issues
Message posted on 12 Aug 2024 04:43 PM
recording issues
From I changed my internet to sky, I have been having problems of when i record a programe and go to watch it half og the programe is not recorded due to power cut as it says on the tv but there has never been any power cuts in my house so unsure why it keeps doing this and not recording programes fully.
Message posted on 12 Aug 2024 04:49 PM
Re: recording issues
When Recordings fail it can normally say due to power cut or software issue. However It's rarely the case.
Try a Reset Settings in the main Q box hidden menu.
